Nouvelle radio Turnigy TGY-i10 10ch 2.4Ghz Digital
Message  Murphy le Lun 12 Jan - 16:53
Voici une nouvelle radio sur le site de HobbyKing. C'est la Turnigy TGY-i10 10ch 2.4Ghz Digital Proportionnel.
Caractéristiques principales :
• 2.4 Ghz AFHDS 2 (automatic frequency hopping digital system)
• Compatible with all TGY AFHDS receivers
• Real time telemetry monitors signal strength, Rx voltage, flight pack voltage, RPM and temperature
• Audio and visual warnings when limits are exceeded
• 3.55 inch, 240 by 400 pixels (WQVGA) colour, high contrast TFT-LCD touch screen
• Power on/off safety feature
• 3 way switch x 2, 2 way switch x 5, momentary switch x 1 and slider control switch x 2
• Easy access pop up / down VR controllers x 3
• High-precision double ball bearing gimbal and ergonomic design
• Double antenna structure for improved signal transmission
• 20 model memory including memory expansion slot
• Free software upgrades available online
Fonctions émetteur :
General functions: Flight conditions, linear, curve mixing, functions, channel, throttle delays, channel mixing, logic switches, Aircraft type, RX setup, dual rates, expo, endpoint adjustment, channel offset, trim, subtrim, throttle down, curve, delay, reverse, system menu, model name, timers etc.
Airplane / Glider functions: Aileron, flap, spoiler, elevator to flap, butterfly, V-tail, dual elevator etc.
Helicopter functions: Throttle hold, mix, curve, pitch curve, swashplate mixing, type, ring, governor, gyroscope etc.
Spécifications :
Channels: 10
Model Type: Helicopter / airplane / glider
RF Range: 2.4055-2.475GHz
bandwidth: 500KHz
Band: 140
RF Power: Less than 20 dBm
2.4G system: AFHDS2A
Code type: GFSK
Low Voltage Warning: Yes (less than 3.75V)
DSC port: Yes (USB, HID)
Memory Expansion: SD card
Antenna Length: 26mmx2
Weight: 620 grams (with battery)
Battery Capacity: 3.7V (1700mAh)
Dimension: 195 x 189 x 43mm
Livrée avec :
(TGY-iA10) 10 Channel 2.4GHz receiver
(TGY-BA1700) Li-ion battery 1700mah
(TGY-ATM01) Thermometer sensor
(TGY-AVT01) Voltage sensor (optical module)
(TGY-APD02) RPM sensor
(TGY-AEV01) I-bus receiver
Micro USB cable
Stylus pen
User Manual (CD)
Prix environ 160,00€ port compris depuis HK Hollande.
Commandée, arrivage dans la semaine.
